i wish the vray would run at gpu stream processor and will be a lot faster than on cpu ![]()
We are, of course, thinking in that direction. However the GPU technology is quite unstable yet, with completely new hardware coming out each year, which makes any long-term plas quite difficult to make. Hopefully the GPU technology will settle on a standard sometime soon, so that development can be more predictable.
So if you coded vray to work on an 8800, would it not work for many other new cards after that?
I don’t have the slightest idea… which is part of the problem
What if someone comes out with a better hardware solution and the 8800 architecture becomes obsolete - we’d have to start all over again.
Excellent technology, potentially a revolution, but thanks to one little oversight in creating a standard it becomes completley and utterly useless. :lol:
More curiosity - would you have to re-write the way that vray does its calculations or is it just updating/optimising all the code to use the right parts of the hardware?
It’s a MESS ![]()
I was reading some page (watch it, it’s a pdf…) on mathematica accelerators: dedicated, parallel processing units that come on a pci-E card, from http://www.clearspeed.com .
The principle is VERY close to that touted by NVidia (the article on CUDA had a link to the “similar” clearspeed boards).
FIGURE 6: STANDARD C
#include <stdio.h>
#include <math.h>
#define PI 3.1415926535897932384f
#define SAMPLES 96
int main() {
double sine, angle;
int i;
for (i = 0; i < SAMPLES; i++) {
// convert to an angle in
range 0 to Pi
angle = i * PI / SAMPLES;
// calculate sine of angle
sine = sin(angle);
FIGURE 7: PARALLEL C
#include <lib_ext.h>
#define SAMPLES 96
int main() {
poly double sine, angle;
poly int i;
// get PE number: 0...n-1
i = get_penum();
// convert to an angle in range 0 to Pi
// calculate all sine values simultaneously
sine = sinp(angle);
To make it simpler: forget the “For/Do” cycle entirely…
I don’t know, lol.
Lele
Thats not too difficult then, vlado just needs to open his code in word and do a find/replace to change ‘for’ to ‘poly’
:lol:
(I’m guessing its a pretty big job then…)
