Hi, Guys! Congrats with new version of Corona renderer. I am rendering an animation in Corona. It is an interior but very heavy one with heavy proxy the polygon amount is almost 40 mln in already optimized scene. Trying to cut render time down to a reasonable one, something like 1hour on 2Xeon 32 cores. Still there is noise mostly in the GI pass. For the moment I have AA/GI on 20/4 MSI 11
The HD success rate is very low. What could cause that? What is the relation between success rate and amount of geometry/lights/reflections? The number of rays is ok IMHO 6.5 mln is ok isn’t it?
Whatever I will really appreciate for some advise /help. I don’t want to use denoiser as this is bluring the image and washing the clean sharp details, after testing I did not find any difference between Corona denoiser and Red Giant denoiser or Neat video plugins, except is fully integrated in Corona and doesn’t need to buy additional expensive plugins. Sorry I can not attach the full image and the scene due to copyrights and NDA.
I pondered upon this too, as this applies to lot of my (surprisingly interior) scenes as well. It’s usually glass and metallics. Previously HDCache (deprecated) had threshold up to which it would work.
Usually, for a modern interior, simple scene, HD rate must be between 50-80.
With the UHD you cannot control nothing about Cache, except fo the two preset
Still: bigger sample with less subdivision
Animation: smaller samples with more subdivision
I suggest you to use Still, if you are working for single renders.
My suggestion is to try to render with in clay and see if the problems are in the shaders.
Then hide some heavy geometry etc…
You can also install the good old A6, with the HD and see if the result is better.
Honestly, I would like to have more control for the UHD ![]()
Yeh, There is a hell lot of Golden heavy details and glass chandeliers.
I just realised that the soft furniture using faloff in diffuse is clean after 10 passes, but I still have noise on the wall which is only diffuse with sight reflection/ glossiness , just semi matt paint. Any suggestions regarding this? Is this a normal behaviour? Actually this noise still persist in GI pass while the other passes are pretty clean. Increasing the GI it will decrease AA and I have a lot of reflective edges which at certain point start flickering.
Thanks guys
Low-glossy flat surfaces are worst offenders. I am not sure if they didn’t receive less sampling previously because of lower reflectivity but perhaps Adaptivity should of have solved this in 1.4. Didn’t do extensive testing yet.
Just a test - taking down the reflection in the material did nothing to the HD success rate still tough the level of noise has not change much. I am not really sure how the Adaptivity works - is it similar to Vray, like raising more samples in the difficult areas? As long I understood from the actual post regarding Adaptivity/ Denoising the samples are brought from the other areas, weakening them( pouring the quantity) Is that correct? What this figure 5 in the box means ? 5 samples? 5subdivisions? a relative number?
Well, I am glad to see these results. As I have mentioned below I am not considering the denoiser serious untill I could prove this really. For the images 600X600 or thumbnails probably it is ok but for prints like 8000 this is not a solution. There are much more powerful denoisers for still images like Imagenomic Noiseware , I just mentioned Neat for instances as it is powerful cleaning the noise in Video sequences. Again I am not going to go in comparison Corona VS Neat or REd Giant or anything, these are too different products with different purposes to be compared to. tBut the reason I have raised this questions
I do not want to trick the result, the render should be clean without using denoisers as they are cleaning picture by blurring pixels which is not accurate( for different purposes though). Whatever regarding to my researches here is the result after turning the adaptivity off: The HD success rate raised to 41 and the noise is almost gone after 100 passes which gives about 30 % performance. Below is the result in comparison.
Render time for 150 passes Adaptivity on 1h18 min Adaptivity off 1h 04 min,
That’s quite surprising result.
I am really surprised as I am feeling that something is wrong. I hate do not understand what happens every time I do something. Again can anyone tell what is this adaptivity, how this algorithm works, why the result is opposite than you expect? Jurai, you are the most experienced guy in Corona, could you explain how this relates to samples? I am still in the dark and hate guessing even though there is a result but the most important question is Why?
I can only guess again that is making the noise more obvious and easier to detect and clean by denoiser
I am not expert on Corona’s sampling at all, Maru and the devs are :- ). You can always send them a scene to test.
I have yet to test and compare how the adaptivity works (although I dislike spending time on doing such tests, I am not even systematic enough).
I’m not expert like Juraj, but with adaptivity, Corona will spend less time on “easy” surface/shaders, and he will concentrate his energy on the most difficult areas.
That’s why, with adaptivity ON, simple flat surface have more noise. But, at the same time, complex areas (DOF, MBlur, heavy glossy surface) will be much more clean (in the same rendertime)
In my opinion, if your “complex” area s aren’t too much (like 10% of your image), maybe, it’s better to turn off adaptivity…
But, we have no parameters for to tweak the adaptivity. Or ON, or OFF… And adaptivity recalc doesn’t change a lot the final result.
I would like to hear some official Corona answer ))
… and not even that is assured in future…
Good Luck
I am not an expert neither, but I would like to know what am I doing instead of testing. I found these new features quite interesting, for some of the guys might absolutely worthy, not for me yet, as I am not playing much with DOF and so… What I would really like to have in Corona - more flexibility and real improvements for sampling, probably material subdivisions, better lighting behaviour. So far the guys made absolutely stunning job. By the time Corona will come to 3.3 version I am sure it will be an absolute winner.
Might be useful for testing, you can take a look at what adaptivity does using the CInfo_SamplingFocus render element, brighter areas show where more processing is being done. Have to have enough passes for it to show up (e.g. for default of Adaptivity recalc of 5, would need to run for at least 5 passes to see anything in that render element).
Hi, this caught my attention:
What does it mean? Does it mean GIvsAA 20, LSM 4?
The it wouldn’t make sense. If you are getting more noise in GI pass than in direct light pass, then you should lower LSM to 1, or even lower (probably not less than 0,5 though).
