hdr setting problem(no enviroment file)
when I load a hdr texture,all be default will work fine.but after changed output option,vrscene has more additional data, (look up i uploaded image),then vantage has losed link of enviroment file.
any helps ?
Hi max_romju,
Are you editing the vrscene and then importing it in Vantage? Can’t you reexport the scene from Max without the need to remove stuff from the vrscene?
Alexander
I open the vrscene just to show the difference about two scenes; the (default) is ok and the (output option ) doesn’t work;
by the way ,the changing of (coordinates) work well; for example:uv offset (3ds max platform)
From the screenshot I see that you are using a Max Bitmap texture. Can you try with a VRayBitmap instead?
yeah, it work .thank you very much
