Hello Corona Comunity, I want to share a Scripted Plugin tool to control your HDRI files and backplates within 3Ds max fully.
Description:
HDR Total Control for Corona allows you to Set up and control HDRI files and backplates for lighting your scenes with a dedicated, intelligent UI with collapsable menus to avoid interference with your menu workflow.
Features:
Collapsable Menus and dialog…
Preview HDRI file Easily…*(Base on a pre-built preview image or automate preview generation based on the file exposure info)
Control your HDRI Exposure, Temperature, Color Saturation… and More
Rotate, Flip, Change HDR Mapping with Ease…
Apply Bakcplate, Infinity plane and Shadow Catcher automatically…
Save and load all options by scene Automaticallly…
Hope you guys like it, any comments, critics, and/or suggestions are more than welcome.
**You can find the the utility [HERE ](https://gum.co/NYtJH). If you have any questions you can DM directly in the Forum or you can use the following [Contact](https://www.behance.net/Tony_Lopezb) information.**[/left][/left]
[/left][/left]
Compatibility:
3ds Max Version: 2014-2022 —> Max 2023(WIP)
Corona 4 or higher —> !NEW! Corona 8
Detailed Description:
- HDR Setup
Load HDRI
Preview HDRI
Show HDRI In the viewport
Clear HDRI (clear any HDRI/Environment Setup in the current 3Ds Max Scene).
Set Corona Render (Assign Corona Render as current Render engine)
Set HDR Lighting (Set up and assign the selected HDRI file to the current scene)
- HDR Settings (Enabled ONLY after load and Setup HDRI file)
>Intensity Adjustments
Exposure Control
Gamma/Shadows Control
>Color Adjustments
Temperature Control
Saturation Control
>Environment Adjustments
Model Mapping (Spherical, Dome, Mirrorball)
Flip/Mirror HDRI
Rotation (-360 to 360)
Camera Height (*Dome Mapping ONLY)
Dome Radius (*Dome Mapping ONLY)
- Backplate Setup
Load Backplate
Visible in render (“ON” by default)
Use in Reflections (“OFF” by default)
Use in Reflections (“ON” by default)
Flip/Mirror Backplate
Infinite Plane (Create infinite Plane with Shadow Catcher)
Clear (clear any backplate setup in the scene)
Set Backplate (assigned the loaded backplate to the scene and render visibility) [/li][/list]
This option is not integrated into the plugin yet but sounds like a really good Feature for the next update, I would look into this to find the best solution for your request.
Thanks for reaching out, I tried to answer your email but I got a delivery issue several times, yes our plugin runs down to 3Ds max 2014, that is the oldest version Corona Render support unofficially.
Hello Gabiru, Thanks for your interest, Unfortunately, every license is unique and linked to your email and system, if you want to use it on more than one PC you will need to request a new license for each system you want to use the plugin with.
Sorry about the email failure.
I sent you an email via a different one, could you see if it works by replying please.
At that point I will purchase the plug in.
