Just curious if there is a way to set the Hdri to ‘invisible’, but have it output as a separate pass? I’m using the lightdome light with an Hdri pluggin in.
I think in a previous version of Vray I was able to set it to invisible, but it kept it with Alpha. Or no? I’m using the latest stable build released for my work.. no nightly
builds yet.
thx
If you set Dome light to “Invisible” you will get alpha on it.
In your case you could try to set the HDR file as a Background texture and keep the “Invisible” option for Dome light on or you can use Multi-matte render element to extract the background (Dome light HDR) in separate pass.
