HDRI Background Wont Save
I rendered several images with an HDRI background. The actual background image won’t save in my file. How can I save it?
Spent all day rendering. So now, if I can add it in post process, that would be find also. No more time to render.
Re: HDRI Background Wont Save
No worries anymore. After poking around, I realized saving as a TGA was the answer.
When using the Batch Render tool targa files are saved with an alpha mask. Pretty cool.
If you save as PNG file and have the alpha channel listed under VFB you’ll not get the background. If you remove it from the list, it’ll save the background. This is only possible in SR1.0 and later.
