Hdri + color correct not reacting in Live link
Hello! My problem is when i set up hdri in vray it shows in Vantage but when i put color correction and change the parameters of color correction nothing happen in vantage.
Hi Martin,
Color corrections for the Environment is currently not supported but it is in our TO DO list. As a workaround you have to bake the color corrections/gamma to the HDR to use it in Vantage.
Alexander
Ok thanks. How can i bake it? To tweak it in photoshop before max?
Either in Photoshop or from inside the material editor right-click(if using the Slate editor) on the color corrections node and choose Render Map… Set your render resolution to the HDR dimensions and in the Output select either EXR or HDR file as output and click Render. The saved image should have the color corrections embedded and with preserved dynamic range.
Alexander
I am Corona user but Vantage is the future :smile: Thank you for the info.
