HDRI Image sequence
how can I load an hdri Image sequence in corona for c4d?
Normally in c4d you can just load it as bitmap and set it to animation in the bitmap shader. But this seems not to be supported by corona? The corona bitmap on the other hand does support animations.
Any ideas?
Thanks!
Hi there,
This should work for Corona as well. I have tested animated textures in the past and have got them to work. Changes will only be visible when rendered.
thanks for your reply!
It does work here with C4D native renderer but as soon as I switch to corona it does not work.
Did you use the normal C4D bitmap shader?
I think from memory I was only using a standard C4D shader for this.
