hi, is the a way in corona to control the hrdi intensity multiplier and inverse gamma like in vray with vrayhdri map?
ive used the vray hdrimap, balanced all my camera and lights, then realized i dont have vray on my render nodes so it wont render. i dont really want to be adjusting my camera settings again. so, is there another option?
Bitmap node has output rollout, so you can control HDRI intensity directly there by adjusting output amount. Also since 1.6 CoronaOutput has exposure adjustment as well as gamma spinner, so you can plug your HDRI through CoronaOutput node and do all adjustments there.
Ok, tried it out myself with latest daily build installed. Exposure in CoronaColorCorrect map works as expected, and there’s no need for restarting the render or IR to see the changes.
