I added hdri to the scene. Lighting seems to be fine, unfortunately I don’t like the hdri background. Is it possible to insert the hdri map separately and control its saturation and brightness independently.
Yes, just goto render settings, Scene tab, Overrides and then use Direct visibility override. If you want to control the intensity and saturation then plug the hdri into a color correct node and then drop that in instead.
