HDRI Lightselect layers
It would be amazing if in the same way you can control the environment slot in lightmix, you could add multiple environment maps and control them with lightmix too.
So for example load in both a day and night environment and you’d only need to render once but you could control the lighting for both states.
Apparently this is not possible:
https://forum.corona-renderer.com/ Multiple env lights... #msg127972
Ah ok understood
