HDRI problem
Hi!
The problem with hdri maps. Cinema 4d R16 and Corona Alpha4. Everything worked perfectly. But today, when I start rendering , I see only blue sky. In the viewport HDRI maps reflect normal. The settings I change only multiplier in Corona Sky tag (0,1). I don’t understand why, in the morning everything worked good.
I reinstalled Cinema 4D to reset the settings and reinstalled Corona. But the problem remained.
Sorry for my english
Do you have your hdri in Tex folder?
delete tag sky
I always load HDRI from another folder and never had a problem.
Thanks, I’ve already tried it. Then there is no problem with the renderer, but with tag sky is easier way to adjust the light level.
And before that it was okay. I have added hdri to the sky with tag. Everything worked perfectly.
Apparently I convinced myself that it worked with the sky tag.
I agree, the Corona sky tag is the problem, its overriding the HDRI
