HDRI refl;ection maps are causing pixelated renderings?
I’ve run another tests on your scene - but I am not sure if this is the result you are looking after.
Here is the result with HDR-image in the background with similar frosting appearance like the image without it.
This result could be achieved by decreasing the intensity of the HDRI image or adding a environment-override map for the frosted-shader.
In the example above I have used two versions of the same HDR-map - one in the Reflection/refraction environment with high-intensity and another one with lower intensity into environment-override slot of the material. The purpose of this work-flow is that you are now able to control the reflection of the frosted-material separately and by decreasing the intensity of the HDR image noise disappears.
