Hello everyone,
I have a minor problem with a render set: I have imported a HDRI sky for my environmental background; however, the scale of the HDRI or my model does not place it in elevation frame. When I tilt the camera 65 degrees up, the blue sky is visible so its there. I do not know how to scale it to be within the background of the model. Would anyone know a fix. Attached are some images and my setting:
Thank you for any help!
Matt
I figured it out. Rhino camera was in a parallel view instead of perspective…
Dear matthew_gundershaug, hello.
As far as I see your examples are renders from Ortho views. Please take a look at the very good explanation here.
If you try rendering from a Perspective view, you will see the difference.
In you case (if Ortho is necessary), I could recommend using Background (as a color correction layer) directly from V-Ray Frame Buffer, see here.
You could try there different opacity levels and placement. Keep in mind that this approach is similar to a collage, so don’t use images meant for spherical projection (like spherical panoramas).
TS
