Hi There I need help in using a HDRI spherical image as an environment where my item (car for example) sits correctly on a flat floor. Shadows and reflections would be a bonus without having to do two seperate render passes
This is a timelapse in max, but should be pretty easy to pick up on the best practices to use. Obviously this is quite a lot of detail - you’re possibly only looking for a single plane and a half sphere to wrap the sky in.
Thanks for the response. Cripes, Max. I thought this was a Maya forum. I supose the principals are the same, if thats the case I think I can get my head around it having done projection mapping before. Always a pain with floors to work correctly though.
