Obviously many people have different views about using HDR vs Sun, but what are the pros and cons of the both, pass the obvious ones.
Secondly, I have my HDRI set up in Environment, one for GI, and the other for Background, both set up as bitmaps [they are both .hdr files], previewed as spherical, but when I render my Image it is really dark, 100% dark. The Image is actually an exterior BRIGHT scene. But when I add the vray sun, it has all the reflections of the HDR Image, and its lighting atmosphere, and its really well lit, but if I take the HDRI out, and switch it with a vray sky, then the colors change. Should I keep the HDRI, with the sun, or should it be with out the sun, If so, how can i keep the render well lit? I tried increasing the multiplayer by 8, then 9, then 10…but still DARK.
Thank you and sorry for the noobness.
