Hi everyone,
I’m searching out how to have good settings for HDRI but even by searching the forum, i can’t get a good result with the HDRI visible and the light which come out.
Can anyone tell me the trick?
You’ll have to give a little more info on your problem. Post a screenshot or explain in more detail.
There are no settings you have to change to get HDRI working, just assign the texture to a CoronaTexture and put it into the enviroment slot.
If no light comes out, you may have accidently put in a Low Dynamic range image, like a jpeg.
For more details lookup the official HDRI tutorial from corona:
Look at this.
French language.
http://frenchcinema4d.fr/showthread.php?81464-Hdri
Ah voilà quelqu’un qui comprend mon problème.
Merci!
Salut Colas,
Je te conseil les hdri de Peter guthrie. T’auras pas mieux ! https://www.pg-skies.net/
Aucun réglage a faire, tu plug ton hdri dans ton diffuse, that’s all.
Merci pour le conseil. Je regarde ça de suite.
