Hey Guys,
after some tests with sss2 i found a setup that works pretty well for me.
i can post some settings if you interested.
so long…
Absolutely. All settings are appreciated.
Hey Jeff,
here you can have a look over the setup.
Only 3 vray lights (backlight without shadows) no Hdri, no Gi. The Main trick is the creation of the Spec Map to control the reflection with the VRay Mtl.
Its also importend to work in a scene with real scales to control the SSS amount exactly.
Greets from here
Tommy
Special thanks to Rusko Ruskov from Chaosgroup, for the short talk at FMX2010!
Thanks for that. Very interesting settings!
Great stuff. Could you do a 360 where the model turns and the camera is locked? The light interaction would probably make it work even better.
Mikokariadis - I didn’t rotate the lights because at the time the highlights didn’t look good at all angles but now I’m using a shellac material to add highlights from a vray standard material instead of using the built in highlights from the fast sss2 material.
Good point on the shellac. Taking note, this may come in handy.
