heavy corona bug with other plugin OSX
for some reason when i install corona plugin for c4d studio r17.048 on my mac OSX machine, the plugin of maxwell render does not work anymore… if I remove corona plugin, maxwell render goes fine.
what happen???
maxwell render plugin write: SDK call writeMXS failed
with the previous RC5 corona plugin everything works fine!!
I try remove all plugins from plugins folder but nothing changed..still crash problem on macOS Sierra & C4D R18…
Hi, could you please install the following special testing build and send us the error message if here will be some? Thank you
https://drive.google.com/file/d/0B7xyYS3daSJ7QkJEaGE5bXpCRnM/view
i try to install it but the problem with maxwell render plugin still remain…
Does this problem occur immediately when you start the Cinema4D or you must do something more? Otherwise. I will probably need to install testing version of Maxwell.
the problem occur when I try to launch a render with the maxwell render C4d plugin… but if i remove corona plugin, then maxwell render works fine!!
So, I installed Maxwell renderer for C4D. Next I clicked Plugins → Maxwell → Scene and Plugins → Maxwell → Render Render View and it works for me. So I would like to ask you what the exact procedure is? Could you describe it or better create a screen record with the problem? Thank you
what version of maxwell do you install?? i use maxwell render version 3.2.1.2 for OSX…
I open a c4d scene…
plugin
maxwell render
render render view
he start the render, but after count scene element, he failed to write MXS…
if I delete corona plugin, he works fine…
this with C4d r17.048 and maxwell render 3.2.1.2 and OSX 10.9.5
firstly thank you very much for your interest,here is message when I hit “Render” button;
Hi walterfog,
sorry for not replying so long, but we tried to reproduce your issue with Maxwell 4 and everything was alright. It could be only happening with Maxwell version 3, but unfortunately we weren’t able to activate the version 3.
Anyway, what’s the current status of this problem? Does it still happen to you? It would be great to find the cause of this.
