Heavy Scenes Renderstart-Times extreme slow
I have experienced the same. And now imagine you like to render an animation locally… No fun.
But would be great to see, if you could compare it by using the same file with a Noise Treshold like 0.05… only one frame, to see if it starts earlier…?
Thanks!!!
Hey @haniel1107 it has nothing to do with rendersettings it seems. I figured out what the culprit is. It seems V-Ray 5 has somewhat a big problem with many clones/instances. I try to figure out what exactly. Because even only grass is in the scene → Scene hangs like in the video.
Yo I found out what is happening. And the result is somewhat fatal.
So it seems V-Ray 5 has a BIG PROBLEM with clones/instances.
The more instances/clones are in the scene, the slower it becomes to start.
I know that this is NOT happening with V-Ray 3.7. Iam currently rendering a scene with millions of clones in 3.7. It starts almost immidiatly.
That is horrible. I just have 16000 clones of a flower but V-Ray starts after 5 minutes or so (incl. the whole scene).
I will test more.
Here 15000 plant clones load in seconds, your best bet is always to send scene to developers so that they can check what’s wrong in the scene;)
A couple more tests, scattered geometry 8.000 polygons, 150.000 clones took 12 seconds, 1.500.000 clones 30 seconds, I’m using a cloner with multi instances
Dont know why this happens to me but I have bad news.
I just made a scene with one cloner which has a cube in it with 200x200x10 Cubes as Renderinstances. In 3.7 it was fast as always. In 5 it was horrible slow.
In the scene theres nothing. Not even light. Just a camera and Cloner with Cubes. Not even a material is in the scene. I checked it a lot with different setups. Its always when there are a lot of objects in the scene.
I tested it with V-Ray 5 for C4D R23 but I tested it also with R21 V5. Its the same…
Here the Video:
I also tested it with GPU Render of V-Ray but as I said: It has nothing to do with Rendersettings, Materials or anything. It seems V-Ray 5 has translation-problems from Cinema Polygones to V-Ray internal proceeding.
Which leads to horrible starttimes the more instances you have. Doesnt matter if these are proxies or geometry. I tested it with Null-Objects instead of geometry. V-Ray starts immediately. But if there is instanced geometry, nope.
Ok now I see… it seems its a problem with Renderinstance itself.
If the cloner is set to instance. Its fast as 3.7. Is it converted to single objects. Its fast. BUT if its set to renderinstance or instances as renderinstances then… slow motion-Terror happens.
I’ll try the same setup to see if I’m getting different results
I hope I replicated the scene setup, cloner with 100x100x10 render instances (?) and a cube with dimensions of 200x200x10.
Could not choke it though, here is a quick screen capture with both image samplers
https://drive.google.com/file/d/1IGj0zFKRh\_ENZS7rd0a-MX9lewJy3XyA/view?usp=sharing
There is something wrong for sure, as I had the same experience. Not only once. I will do some tests, too. Will try to reproduce the issue.
Would be great to find the reason..
You have it set to Render Instances.
From my experiments over the weekend. I’ve reported an issue with Render Instances.
My post is in the C4D V-Ray issues.
Render instances appear to have some form of a bug. Multi-instance is the way to go. Even regular Instance is faster than Render Instance.
Worst possible setup is
1) Cloner with Render instance
2) Any material assigned to the Cloner tag vs object it self
3) Material Tag with Tile option unchecked.
You don’t even have to get to thousands of clones, to experience complete halt in rendering.
If your V-Ray scenes are slow, check those Cloners. Make sure you avoid all of the items above. Otherwise you’re in for the wheel of death experience.
I’ve tried your setup with multi-instance, and it renders immediately. When I set it to Render Instance, my C4D froze up.
I cant use multiinstances because I use Vray Proxies in conjunction with Cloner set to renderinstances…
Hope Chaosgroup fixes that soon. Its very essential. I use cloner and instances set to renderinstances A LOT.
Have you tried using straight instances. Seems like it’s working faster than Render Instances at the moment.
Are your proxied projects/mesh contain cloners which contain render instances?
I tried instances, which is of course brutally inefficient.
Iam using Cloner set to Renderinstance which contains Proxies.
If not then Iam using real geometry with renderinstance set. But thats absolutely the rare case.
Working with instances are slow in viewport and as far as I know: even proxies need to be renderinstanced so that they dont eat up my memory. But currently impossible as you can see in my videos. This is bad.
Until this is fixed unfortunately I have to go back to 3.7.
But Chaosgroup is very hardworking right now. Its a matter of time they will have that fixed. Iam pretty sure.
Hope they make this a priority. Because I surely CANT work with multiinstances and I NEED Renderinstances, proxies and cloner. My Scenes are extreme heavy.
So this has nothing to do with noise threshholds, Gi or Displacement. Its just the Renderinstance-Issue.
@ChaosGroup pls make this highest priority because this means I cant work with Vray 5 anymore.
Thx in advance!
Hey everyone,
we’re looking in to this and will share some more info as soon as/if we find something regarding the issue. Thank you for your feedback.
Thank you very much @shaio
I have a scene where nothing happens when hitting the render button for about 4 min..
File size 8 GB
Just some lights / 8 high poly cars and a floor… NO CLONER / NO MULTIINSTANCES
But some warning appear in the console..
Like: (just some of them / 400+ in total)
Multiple assignments with the same material may not render correctly. Material: Car Paint 2 Material, assigned on: Bremse VL
Multiple assignments with the same material may not render correctly. Material: VRCS_EXT_STEEL_SILVER, assigned on: BB
Multiple assignments with the same material may not render correctly. Material: V-Ray Standard Material, assigned on: HL_20170828_body__21
Multiple assignments with the same material may not render correctly. Material: V-Ray Standard Material, assigned on: _shell_02
Multiple assignments with the same material may not render correctly. Material: VR_EXT_WINDOW_CERAMIC_BLACK, assigned on: EX_COM_GLASS_F_WINDOW_TYPE_D__.1
[0h 0m 0.5s] Failed to init Texture RGB Color Space conversion from lin_adobergb to lin_srgb
Can someone explain what those means and could they be the reason, why 4 minutes nothing happens (in this case)?
EDIT: If I go with Material override (Simple grey VrayMat), doesn’t make a big difference…
Do you use the same texture with the same name for an object for several selections?
Benutzt du bei einem Objekt für mehrere Selektionen die gleiche Textur mit gleichen Namen?
Oh yes… this makes sense… I am using the the same brake material for all brakes with selection tag..
But you don’t see it, as the perspective of all cars is frontal…
Thanks Pardalis..
@CG Why isn’t Vray ignoring it, when using material override? Doesn’t it cost too much time?
For example if you compare the material override with C4D Standard renderer and Vray…?
C4D is much faster..
Have you tried disabling ’ Render Hidden Geometry’ in Overrides > Geometry?
