Hello from Mexico!!
Hello mi first post here, i have two months usin vray so i’m a newbie
i’m from los Cabos Mexico, so maybe a lot of the people from usa have come here to spring break!!
This is a departament but is not finished, but i like to have comments!!
If anyone use msn here is mine: rolojero@hotmail.com
Saludos desde los Cabos!!
oi !
beautiful lighting…
i like the dirty irradiance map ! :twisted: it doesn’t look like low settings
cool
cheers
olivierfr
its very good for 2 months of vray experience
salu2
looks very good my friend , you should try give it more light with photoshop … very nice
ta chida , ta chida .
hi
looks realy nice. I am not sure i would make it brighter. Its a feeling of warm suny day a bit humid maybe.
only thing, the reflections on the floor could be a bit less, maybe very small glossys ?
well first bounce maybe a bit stronger for the suny floorpart ?
nice work at last
Tom
nice. hehe. ill be the 1st to point out that you probably meant “Appartment” not “Department”
thanks for the comments!! sure i’ll post the the settings
by the way… the settings for the irradiance map was some i copy from a post i saw here… the render took five hours!! rigth now im only using low medium or higth… don’t know very well how to set the custom settings
mhh i have a question here, i know what is a glossy reflection but i don’t know how to achieve it… :frowning: can you help??
I like the lighting, it’s softer, more calm without the sunlight.
I like the light and the atmosphere :slight_smile:
I agree about reflections on the floor
Where can i find a tutorial about getting glossy in materials? cause i put some numbers in the glossy field of the material and nothig happen…
for example use a 0.5 and u will get very very glossy numbers up to 1.0 will not look glossy so you can call 1.0 the limit.
looking nice, did you use photons for secondary bounces ?
rolojero, maybe this will help, http://www.vray.info/entry.asp?entryID=90
