Help Creating Vertical Garden
Have a project where the clients have designed in a huge vertical planted wall looking like this
Any help of how you guys might recreate this in 3d would be great. Have tried a few displacement things resulting in memory eating up and the result not good enough for the client. Was thinking of doing a photoshop-gig soon but have a feeling it might be look very flat. If I had better ref images I might be able to map it on to some geometry and displace that?
Any suggestions would be great
Cheers
T
tell the client if he doesn’t get you better ref images, be prepared to be happy with the best you can give him. That thing looks a nightmare.
/agree
particle flow with placement maps?
I can think of several ways to do it. The easiest would be to use generic grass and leafy textures and displace parts to make them appear organic. To make it look realistic I would add cutout billboards with foliage and even use hair & fur or vrayfur to make grass. As long as you break it up a bit it shouldn’t be too difficult.
ha! that doesnt look too bad.
One way you can do it is just treat it like a normal flat garden.
Make up some plants or use some plant libraries and place/paint them round the walls.
Would take a little while to do, but it wont be too hard.
If you need some more help let me know im happy to help out. I have become a bit of a lanscaping master with my last few projects :wink:
Couple of 3d plants for major features, shitloads of photoshop.
Doing it in photoshop only looks as good as what youre using, so get out taking ref. photos.
indeed some basic 3d models, with grass as your start layer.
use. evermotion has some nice dvd with plants and maybe some specific plant software such as onyx.
then loads of photoshop indeed :slight_smile:
cheers guys
Thanks for all the suggestions
I have asked the client for a better ref photo/texture to start with.
not too easy since this is dublin and not really the centre of the world. As far as I know the closest wall like this is in Paris. (any french vray users out there :smile: ?)
No time at the moment to do it all in 3d so I think a hybrid version as suggested might be the way to go but first better photos! In the mean time
id better do some crappy photoshop thing because they want an update for tmrw… :twisted: :evil:
Maybe vue 6 could do it.
but.. argh it doesnt use vray, only mental reay if you use x-stream
i think max’s scatter tool would do a great job with creating this.
create a mesh that loosly fits the wall, and is the shape of the particular planting area you want to do. create one of the flowers or leaves with the Onyx or something similar. scatter that object across the meshed surface. i would probably keep the surface instead of hiding it, and do a light vray displace to give the leaves or flowers a bed to sit in.
Ivy Generator
Have you seen the Ivy Generator?
I played with this for a while… Pretty cool; however i did have some problems with importing what was generated with it…
Iwould think if you generate several ivies and place them together with a several texture maps it would at least get you started…
Here is the website:
www.graphics.uni-konstanz.de/~luft/ivy_generator/
Arkitec
if you are doing it in 3d, the advanced painter might be useful.
-oconv
I didnt mean photoshop an existing wall like that over it, I meant to use hedges, random plants and any bits of greenery you can get to mix in with it.
and *lots* of billboard shrub textures :wink:
I did a similar density of foliage (although, it was horizontal) recently using the xfrog shrubs disk’s Billboards directory as a nice set of ‘fluff’, interspersed with *lots* of grasses. main problem in using billboards for you is that everything is pointing towards the sky.. so you’ll have to use a custom ‘bent’ mesh to make things look like they’re leaning out/down
But then, it all depends on how close you get to the building, combined with how likely the viewpoint is to change will decide whether you have to go through the hassle of setting up a semi finished 3d scene for it.
I only went the above way over doing it in post because we were looking at pretty drastic view changes, and a *very* strong likelihood of animations coming in the future.
forget to do it in max…
Photoshop it, you’ll loose less time
Thanks all
Some superb advice, still waiting for better reference photos here. Client is in a rush but somehow very very slow… The usual!
