This is common issue with a low - 8bit - maps use without sufficient underlying geometry.
To solve it, you need more detail, either using higher, 16- or 32- bitmaps, or subdividing the base geometry, or both.
burnin said everything right about 16/32 bit.
But other than that the jagged edges can be due to bad texture - sharp boundaries between white and black.
You can try smoothing the texture in Photoshop: Filter > Blur > Gaussian Blur…
However do not forget about Render Settings: Corona > Performance settings > Displacement / Screen size (px) - for example a value of 0.5 or less.
