help - light spots/noise in night scene
Hi there!
I have a problem with making a night scene in Corona renderer. There is a light noise around the lights and I don’t know how to fix it. I tried every type of lights (MAX and corona) with the same result. I uploaded an image so you can see it, I stopped this render by 30 passes but after 70-80 passes it’s not much better. Please help me :frowning:
Try setting Max. sample intensity to the default value of 20.
I tried this, even higher value but it doesn’t help.
Fixed! I set Light - Samples multiplier to 75
