HI TO ALL, I’VE BEEN TRYING THE NU VRAY SO THIS IS A IMAGE TEST, I GOT A PROBLEM TO MAKE A MIRROR MATERIAL…
WITH THE LAST ONE I JUST IMPORT A CLEAR GLASS MATERIAL AND TURN OFF THE FRESNEL… AND I GOT THE MIRROR… BUT I TRIED WITH THIS NEW ONE.. BUT… I GOT NOTHING… SO… I WISH TO KNOW HOW TO DO!!!
Re: HELP!!! MIRROR MATERIAL!!!
Just make default material, put on reflection and just change reflection fresnel to none. It should be good. Also you can play with wilter color to make mirror lighter or darker
Sorry if I am not right
good luck!
In the new build 1.48… we don’t have the fresnel effect enable by default, so the only thing that you have to do is add a reflection layer.
Step
1. Right click on the “Scene Materials” and select “Create Material”, then click on “V-Ray Default Material”
2.Right click on the material and select "Create Layer, then select “Reflection Layer”. Done
3. Go to the material “Option” section and enable “Reflect on Backside” (if you don’t enable this option the back face will appear very dark or even black)
Best
wow, Ok Muchas Gracias MASTER!!!
is always good to learn from a icon like you!!!
thanks a lot!!!
