HELP: Painting over textures
I made an object and I have put a vismat metal texture on it, how can i paint over the texture? for example if I want some metal objects to look like a green painted metal and some others to look like a yellow painted metal? Thanks in advance and sorry if I confuse you with my english
One option is to add a diffuse layer with the color you want to your material (right below your original diffuse layer). Then, for the first diffuse layer, you can change the transparency to “TexAlpha” and select a gray between white (full transparent) to black (opaque) to adjust the amount of that color to show through. Another way is to use the Color Correction material (change from TexBitmap) Make sure to add your bitmap to the color correction texture and it will still show up in SU to allow for proper UV mapping. That will allow you to adjust hue, saturation, and intensity of your base material.
Thank you! it worked as I expected
