HELP PLEASE! I Have never had this problem before but there is a white strip across my render!! See pic!!
Hi all,
Im using Vray for sketchup to render an interior scene, its all coming out the way I want apart from there is a white strip across the whole image in both vray buffer and when I save the image, why? This has never happened before and I cant find anyone else from a google search that has had the same issue (normally I can solve most things with a quick google search!) Please could someone help me, Ive posted the image.
Is it the camera positioned behind a wall,a furniture or an object?
If yes and you have the clip planes activated, try to move forward the near clip plane distance.
Thanks so much for your reply, It actually turned out my faces weren’t orientated correctly and that was causing the issue! All sorted now.
