help request: light with only sunlight
Hello to everyone, I need your advice.
How would you do to light this room only with the help of sunlight?
ciao, davide.
Uploaded with ImageShack.us
Re: help request: light with only sunlight
you would have to play with the camera settings…
your render will be brighter if you use a lower value for the shutter speed and a larger value for the film speed
also reducing f number makes it brighter…
that’s a begining :stuck_out_tongue:
^ Yes, this would help a lot. It’s the only way i can think of at the moment…
How my friend arqestevez said its all about the phisical camara, tweak on those settings and you will have great results, also check the envoirment settings…GI sky light and background! :slight_smile:
I would also use the Reinhard color mapping for this or else your floor will become really burned out where the sun hits.
