Can someone help me on how to achieve a detailed outline using vray toon? it seems that vray toon is view dependent and cant get all the outline details to produce a line drawing.
Many thanks,
James
The thing is that your reference seems to be a CAD model, where the clear lines are simply the wireframe nurbs.
Toon will rely on normals, so you’ll only get what you are after if the model has sharp enough edges.
So, depending on how you built yours, you could extract mesh loops to describe the shape and render those.
