Help with animated HDR sequence
I have an image sequence of an animated sky in hdr angular map format that I wanted to experiment with. Is there any way to use an image sequence within the VRay HDRI map? The only workaround I can think of would be to transform each frame into Spherical format and use the standard bitmap loader but that would be a right pain.
Any help? When I did a search on here I read somewhere that Vlado may have a script for this. If so, and you read this Vlado, I would love to check it out if possible.
Thanks.
If you create an .ifl file sequence, you can specify that in VRayHDRI.
That worked perfectly, thanks a lot. I never even knew about the IFL Manager utility before!
