Hi, guys!
I need help with the caustic .I’ve never worked with it. I Read several forums, all solutions are there in my case do not work, probably I do not understand something. For water I use box with noize on bump and standart parameters in material. When I am using bidir all begins gradually black. And it’s no matter which mode bidir I use the result is still terrible. I attached two images 1. Render engine: progressive 2. Render engine:Bidir/VCM
Please help me)
Hi Liberti
In Bidir/VCM try to change mode to VCM.
Try simplifying scene for the caustics. Only water all the rest midgray difuse material an light sorces that should produce caustics.
You may want to check this tutorial: My Corona caustic aproach - Corona for 3ds Max :: Tutorials & Guides - Chaos Forum
romullus, thank you so much!!!)))
This tutorial is very useful! As fo me I got a good result. Soon I’ll show it here.
How cool is that, Boris will be very pleased that his tutorial was useful! :]
