Hi there,
I’ve been using Thea render professionally, and am considering moving over to Vray. I’m doing a simple test to get displacement working.
I created a corner, grouped it, and then applied the displacement modifier to the group.
I applied a brick material to the group. (I did not apply this directly to the faces, but only to the group as a whole.)
I made sure displacement was switched on for this group and also turned on “Keep Continuity.”
I’m using RTX rendering (3090RTX GPU). I should mention I get the same problem on CPU and CUDA as well.
Here is the output:
I get this whether I’m using interactive or final render. CPU, CUDA and RTX all lack displacement.
What am I missing here?
[I reposted this from the “General” forum because it was mis-posted.]
