picked up the idea but implemented it as file menu item. Additionally, saving only happens if a save is required (no changed made to scene, relying on getSaveRequired()). Script goes to any autostart folder (usually scripts\startup). Sharing it as an alternate option.
The ‘saving only happens if a save is required’ seemed a bit beyond my capabilities, so I didn’t bother. But this is clever of you, and I feel pleased to have I’ve influenced you, Frood
I’m wondering if someone smarter than me can help figure this one out…
I’m trying to automate ‘Unwrap UVW’ to a default “Flatten: Custom” workflow. (See the picture)
I got a pretty good result with vibe coding (chatGPT) but it can’t quite figure out the final, and most important component. It does everything right but doesn’t get the right result (or at least not the same result as if I manually press that button).
Please see the code below and offer a suggestion if possible. Many, many thanks!
HELPER – unwrap one object, set channel, run Pack-Custom
fn addUnwrapPackSingle obj mapChannel:2 =
local prevSel = selection as array
select obj
-- Add temporary Edit Poly modifier to force full poly selection
local epMod = Edit_Poly()
addModifier obj epMod
epMod.SetSelection #Face #{1..(getNumFaces obj)}
-- Add the unwrap modifier
local uMod = Unwrap_UVW()
addModifier obj uMod
uMod.unwrap.setMapChannel mapChannel
-- Ensure full polygon selection for Unwrap as well
uMod.unwrap.selectPolygons #{1..(uMod.unwrap.numberPolygons())}
-- Set current modifier to Unwrap
modPanel.setCurrentObject uMod
-- Run Pack ► Custom
if isProperty uMod #packNoParams then
uMod.packNoParams()
else if isProperty uMod.unwrap #packNoParams then
uMod.unwrap.packNoParams()
-- Optionally remove the Edit Poly modifier to clean up
-- deleteModifier obj epMod
-- Restore selection
select prevSel
BATCH – loop through initial selection one-by-one
fn batchUnwrapPack mapChannel:2 =
local workList = for o in selection where isKindOf o GeometryClass collect o
if workList.count == 0 then
messageBox "Select one or more geometry objects first!"
return undefined
with undo off
for o in workList do
format ">> Unwrapping & packing : %\n" o.name
addUnwrapPackSingle o mapChannel:mapChannel
format "=== Finished : processed % objects ===\n" workList.count
RUN (change the channel if you like)
uMod.flattenMapNoParams()
uMod.unwrap.flattenMapNoParams()
also, I don’t think you need the edit poly and force selection - so the simplified function:
select obj
-- Run Pack ► Flatten
select prevSel
I would give slightly off-topic advice - do not try to “automate” everything through script, or at least see if it is worth it.
Changing multimap’s seed depends on how exactly the map is going to be found - it is not a straight forwards thing, unfortunately. You either need to get/select an object, then find the corresponding multimap (can be many) and then change the seed. On the other hand, you can open material editor, locate the multimap visually and change the seed. Or you can use a controller (e.g. bezier float) to quickly change it, if opening material settings is an extra click for you. The same controller workflow would apply also for multiple CoronaMultiMaps for multiple objects and materials.
Ironically, if you want to change the seed parameter for all CoronaMultiMaps, that is a rather easy and quick line of code:
maps = getClassInstances CoronaMultiMap
for map in maps do (map.seed = 42)
Another option is to use parameter wiring. I linked the seed ta a custom slider in my example, but you can wire it to almost anything in Max - height of a cube primitive, movement of teapot, etc. Any parameters that has numeric values can be “wired” together. Don’t know how robust this method is, e.g. if you’ll make significant changes in your material, the wiring might brake, but it takes only few seconds to rewire everything again.
A quick search gave me limited help - any idea where I might be able to find good tutorials on how best to use this feature?
Does it work in reverse? So for instance; I have a slider; I change it and the geometry z scale changes). But if I manually change the z-scale of the same object, the slider responds?
Such a cool feature, wish I had more time to play around with it…
Parameter wiring is pretty straightforward thing in 3ds Max and pretty useful too. It’s also easy to learn, i think i’ve read Max help on it, did a couple practice wirings and that’s it. You probably can find some tutorials on YT if you want more streamlined experience. One evening should be plenty enough to learn it.
Yes, it can work in one way, or another, or in both, you have an option to set up parameters relation to each other in parameters wiring window.
