Help with maxscript
Hi !
Looooong time ago, a buddy gave me that script to render objects with several material and save the still automatically with a name convention. Ideal for this routine
I would like to use it again but it’ll be more efficient if Vray frame Buffer,Vray color mapping and max gamma preference could be take into account. I mean, I would like to be able to use fully this script with Vray.
My problem is … I’m not a maxscripter ! and I don’t know if there is a easy way to do it…
Could you help me ?
Thanks.
on vasy pressed do
    outputpath = GetSavePAth "Sauver dans : "
    for obji in objectTorender.selection do
      -- print objectTorender.items[obji]
        obj = getnodebyname objectTorender.items[obji]
        max unhide all
        select obj
        max hide inv
        for dec in $decor do
        unhide dec
        for mati in matTorender.selection do
            obj.material = meditMaterials[mati]
            nomobj = obj.name
            matname = obj.material.name
            sortie = outputpath + "\\" + nomobj + "_" + matname + ".png"
            render  outputwidth:RenderWidth outputheight:RenderHeight outputFile:sortie vfb:myCheckBox.checked
    messageBox "RENDER OK"
I’m not sure I understand what you’re trying to do.
Do you want to cycle through all your scene materials and render one image with all the objects with Material#1 then one image with all the objects with Material#2 then one image with all the objects with Material#3 etc.?
In fact, I’m already use this script in that way :
1-Create a “decor” group which been not affected by material changes and been always rendered.
2-Select objects and materials I want to associate in differents renders.
3-render them all !
So If I have a scene with box1/box2/box3 with material000 and material#1/material#2/material#…/material#25.
I can render :
- box1/box2 always with the same material000 and box3 with material#1 then save to “box3_mat#1.png” then,
- box1/box2 always with the same material000 and box3 with material#2 then save to “box3_mat#2.png” then,
- box1/box2 always with the same material000 and box3 with material#25 then save to “box3_mat#25.png”.
So, this script is ok in that way but my problem is that It didn’t take in account all my stuff with VrayfB,Vray color mapping and max gamma preference, etc…
I don’t know why… that’s my request.
Sorry if I’m not clear… it’s no more in my mind !!
OK, try this:
on vasy pressed do
    outputpath = GetSavePath "Sauver dans : "
        max unhide all
        select obj
        max hide inv
        unhide dec
			nomobj = obj.name
			renderSceneDialog.close()
			rendOutputFilename = outputpath + "\\" + nomobj + "_" + matname + ".png"
			max quick render
Obviously I can’t test it without the rest of your script.
Thanks Dan !
I’ve got a problem with this one… really strange, I don’t have any saved images
Here the (full )new one if you want to test :
rollout exportgm "Export GM"
label label0d "** \\GM_RENDERER// **"
MultiListBox objectTorender "Objects:" items:(for o in objects collect o.name)
MultiListBox matTorender "Materials:" items:(for o in meditMaterials collect o.name)
label label6d "======================="
Button vasy " RENDER THEM ALL!! "
label label7d "======================="
on vasy pressed do
        max unhide all
        select obj
        max hide inv
        unhide dec
            nomobj = obj.name
            max quick render
createDialog exportGM width:200
I think it wasn’t saving because the ‘Save file’ checkbox wasn’t checked. I’ve added a line to do that automatically now and it’s saving files here.
try (destroyDialog exportgm);catch()
on vasy pressed do
        max unhide all
        select obj
        max hide inv
        unhide dec
            nomobj = obj.name
			rendSaveFile = true
            max quick render
sorry for the delay, thanks Dan for the last version of the script, It works nicely !
I had a break with this job so I put it aside but it’s back again these days… and it came back with new demands…
Anyway, I handled almost all but again, I have a question about this script :
Could it be possible to get materials from a specific MatLib instead of taking them from Material Editor ? Idealy, if we could have the choice, it would be perfect !
I tried but I can’t understand how to call and get a specific matlib…
Could you help me please ?
Glad the last one worked :slight_smile:
Have a try with this:
	local matlib = meditMaterials
	radioButtons matSource labels:#("Mat Editor","Mat Library") default:1 columns:2
	MultiListBox matTorender "Materials:" items:(for o in matlib collect o.name)
	on matSource changed state do
		case state of
			1:
				matToRender.items = (for o in matlib collect o.name)
			2:
				matlib = undefined
				matToRender.items = #()
				if (matLibFP = getOpenFileName caption:"Select material library" filename:(getDir #matlib + @"\") types:"Material libraries(*.mat)") != undefined do
					matLib = loadTempMaterialLibrary matLibFP
	on vasy pressed do
			max unhide all
			select obj
			max hide inv
			unhide dec
				obj.material = matlib[mati]
				nomobj = obj.name
				rendSaveFile = true
				max quick render
I have to admit, I haven’t tested it properly but it should work…
Hi Dan,
You are the man !!!
Thanks a lot, it works perfectly !
Thanks for all your help
No problem, it’s good exercise for my brain :slight_smile:
