I didnt want to post tthis in the problems section because I’m unsure if its a problem with vray.
Here’s whats going on…
When I send a job out for net rendering, all nodes render the 1st frame fine without any problems. Then immediately after finishing the 1st frame it was assigned I get the following error on the nodes:
After receiving the error, most of the nodes will get a new task and render several frames without any problems only to get the missing .hdr file error later down the line. I dont understand how it can render it fine and then on the next frame loose a file it needs to render. I haven’t had any problems like this before and the only thing I can think of that changed was upgrading to 1.5. The "ERR " leads me to think is related to vray.
Any help is apprecieated.
thanks
-joe
