I’m trying to put multiple plane objects (leaves) on a poly object (tree)
So the leaf is a plane with an opacity map and it looks fine by it self.
But when I try putting numerous instances of it on the tree surface (I get the same problem with a PF Source Array Object and using the Scatter Compound Object) the opacity map isn’t working anymore.
Here’s an image:
You can see the single leaf and the array.
I also tried using the Hair And Fur Modifier on the tree with the leaf as an Instance Node, but then I can’t assign seperate materials to the tree and the leaves at all.
There seem to be quite a few posts here that belong in other forums, where it’s their first post. Are people really so blatant or am I assuming the worst?
