Help with this bathroom!!!
Need some help wit the noise on the walls, can’t get rid off the strange noise on the withe walls.
hi there
it’d be easier to make a comment if you can post your settings
I´m usin 1 vray light and 1 direct light
First bounce M 1.0
Min r -3 Max r -1
.2,.2 .1 HSsubv 80, Int.samp 20
Second bounce M 0.6
Subdiv 35
Depth 40
Enviroment none
HSV exponential Dark 1.0, Bright 1.0
QMC sampler (early term) amount 0.85, noise th .01
Hey! :slight_smile:
40 dpeth for the secondary rays is completly useless.
Set it to 3-4. It will be the same I guess..
Otherwise just increase the HSsubv to ~120
and interpolate samples 25-30 try both see where you get the best time/quality.
Otherwise it looks excellent to me. Also if u plan to use some textures, put on it and that will hide quite some noise…
Looking good, are the rocks displaced? good chance the noise is coming from them if they are.
