Help with wine cup render (thik I solved)
Hi, is my forst post, sorry but my english is not good,
As you can see in trying to make a wine cup, but the problem is that the glass is not totaly transparent, i can’t see the texture of the floor thru the glass, i think the problem is the refraction layer, because when I work only with the reflection layer I get a transparent glass but not real. i’ll appreciate any suggestion. thanx.
Picture with refraction and refrection
Picture with just reflection
Properties
I THINK I SOLVED MY PROBEM
In my new stage I render the same cups and I got the same results (no reflection of the floor)
I hope this helps someone:
In the first 3 pictures the floor was a component, but as you can see the cup didn’t reflect the texture of the floor. But when i made it an extrude (but still a component) I finaly got the texture to be reflected, I think this solved my problem.
