Distribute rendering buckets are not split and get smaller as they finish a bigger area and you are left waiting that one last bucket, with 105 ones sitting idle!
What is this?
Are we back to the '90s? ![]()
Or is there a setting I missed perhaps?
What is this?
It never worked for distributed rendering unfortunately. Per How Adaptive Bucket Splitting speeds up V-Ray’s rendering …
This specific approach is currently only viable for local rendering and doesn’t apply to distributed rendering, as that requires a slightly different approach to ensure network traffic stays low.
It sucks all the same.
Hope this gets tweaked to work somehow…
Yeah, not having split buckets on dr really cuts into the advantage of adding a second machine. When you factor in the additional time to transfer the scene and start rendering on the second machine plus the inevitability that one bucket will take a lot longer than the others (usually some foliage) the time reduction is usually very minimal even for similar spec machines. Maybe if I was adding a lot of machines (at least more than one) dr might be worth it but as it stands right now it’s not worth it imo.
