Anyone know how to get better antialiasing on the more extreme edges in this image. I used catmull-rom and adaptive at 1,3. which is probably the highest settings Ive ever used.
percy
percy
decrease the treshold increase, the samples, I think nothing more can ve done. sometimes I use even higher, like 2-6 or more but its very rare.
try to lower the treshold if you didnt yet, to something like 0.01.
I want to live there… blurry edges and all ![]()
if it’s a still, I had really good luck by using Catmul-rom, unchecking “filter maps” in the global switches" rollout…and most important using simple-two-level AA w/ 2/5 and lowering that threshold to 0.05 (I think the default is 0.1) …this setup gave me really crisp results w/ bump maps grids in floor or wall tiles…
hope this helps,
paul.
PS: this WILL increase your render times quite a bit…but I think it’s worth it…
Render twice as large and resize in PS.
This color palette looks really nice 8)
--Jon
What does this “Twice as large” and resize in PS trick do?
Isn’t it the same as Fixed rate with 2 subdivisions?
