Hi, I’m using Revit 2016. The “grass” keyword seems doesn’t work while others are OK. I also try to change the material name as “tall grass” or “wild grass” as the tutorial says and it does’t work as well. I downloaded the revit sample file and it can’t work as well. It that because I’m using a Chinese version Revit so it can’t read the material name or other problems? Thank you!
Hi, thank you for responding. I’ve checked the tab and it is on. So it’s quite weird.
@Phenix_Zhang , sorry for the late response. Is this issue still persisting? If yes, could you please try our latest release to see if this would resolve your problem? To acquire our latest release just click the [About] button and then “Visit download area”. Thanks in advance! ![]()
