Hi Res Render
Hey guys, Is there a way to render an image in a higher res than 8000x6000 pixels? :?:
it crashes on mine, 8000 is max i think :S
Is there any way to break down the image and render it in segments?
This really pisses me off!
Bt the way… SKISAME STO PODOSFAIROOO! :mrgreen:
turn off Rendered Frame Window. THen it should work just fine
if you are using max 6 you can use the render stripes.
Travis
Thank you guys… I will give it a go! :slight_smile:
you can also try BIGRender script from Tomas Cayuela Caudevilla
you can find it on the scriptspot …
basically it makes you define the infinite number of regions (or pieces) that you want to divide the scene to … and then you should only do the composition in PS …
Actually, it would not be a bad idea implement that function in the Vray V.1.5 …
