Hidden Light Problem
I’ve got a strange behavior of spotlights, when they are hidden behind the objects. From close-up I get the effect I need. But when I go further away, at a certain distance the lights stop shining and make a strange reflection on the wall. I have recreated the situation separate from the project, so this issue is definitely effected by the distance of the camera. The screenshots are attached. Is it a bug, or just some kind of optimisation for the calculations?
Thanks in advance,
Andrii
I have to add, that when I walk through the scene, it shines correct, but as soon as I stop, it gives this result.
I work in Rhino 6 and the Latest Enscape Version 2.5.1.9
@Andrii_Mogylnyi , this should be a normal behavior due to optimizations which help with performance. To make sure, could you briefly send me the project at hand? You can send a link to download it via PM if that suits you better. :slight_smile: Thank you in advance!
Hi Demian,
Hear is the link:
https://wetransfer.com/downloads/166a8224977fd9b37ab692171be7d82920190430121651/734c8df00cbf5c8bd33381fee815123420190430121651/2a44b8
I cannot send the project itself, but this is the simple replica with the same result.
Thanks a lot for the project file @Andrii_Mogylnyi , this is indeed a normal behavior. Further optimizations will be implemented to our lights in general of course, so thank you also for your understanding. :slight_smile:
Thank you for your answer! I am looking forward for the further improvments and development of new possibilities. You are doing a great job!
