Hide/Unhide VFB Window to MacOS Dock Bug
Use Cinema 4D R14 on MacOS 10.11.6
Corona version: A6.3 (core 1.5 )
Set default VFB setting on “Corona VFB”. Start render and when I hide window to Dock I can’t unhide it back. Try open it from “Corona menu → Corona VFB” but nothing happens. Render still work on background. And then I press “Render View” button and… crash!
You can see my crash-report on attach file
Somebody have the same problem?
_BugReport.txt (127 KB)
Hi dangear,
I am sorry for the problem. Can I ask you what will happen when you click the minimised window on your dock or you can’t see it on the dock because you closed it? I am asking you because I can’t reproduce your problem. When I close the window I can open it again by clicking “Corona menu → Corona VFB”. But I successfully reproduced the problem with viewport rendering when rendering to PV or VFB is already running and this problem will be fixed in some upcoming daily build. So to workaround your problem you can simply minimise the VFB window instead of closing it or you can try to use Beta 1 daily build https://forum.corona-renderer.com/index.php/board,40.0.html.
