I am working on a short animation of this high-rise, this is a preliminary rendering, I am still tweaking materials to achieve more realistic look of the facade and reflections. Righ now I am using HDRI map both for GI and reflections and glossy reflections for that “alucobond-like” panels material. Any suggestions how to improve the materials ?
Am I wrong or will we see a lot of renderings with Natty’s fabulous silver material? It’s kind of ood to see it applied so ssystematically on the whole tower. Maybe a little variation with a less reflexive and shiny material every once in awhile would outline the details…
As for the vertical lines, I always watch for them in stills, this is going to be a 40 second animation and the camera is looking up most of the time so I can not avoid this distortion.
Anyway, I have decided for a twilight scene finally, here is another test frame (low AA, low samples).
The last image need a little bit of adjusment…the view looks like its distorted too much..usually this kind of view is suitable from ground to up but not halfway from the middle…repair the prespective a little…try to get 1 of the corners straight.
j_bug : what kind of errors do you see ? just to explain the interior geometry a little bit - the ceilings are just flat slabs with some irregular lighting pattern mapped on them.
Actually, that has been done intentionally. I am trying to show some offices with the lights on and some others vacant, with the lights off. So that is why some ceilings are black.
The black I was referring to on the ceiling is pure black in the third image down. It didn’t really look like the lights were off but almost as if the tiles were missing and some construction going on. Maybe they’re installing new network cables :lol:
What are your light settings? The new image appears to have a falloff of some sort and doesn’t represent sunlight well.
The black I was referring to on the ceiling is pure black in the third image down. --Jon
Yes, those were errors on the ceilings (double faces), I fixed that soon afterwards.
As for the lighting, I am using just one direct light for the Sun and a HDRI background map for GI and reflections. That fall-off you see across the building is caused by other low city street buildings standing around (invisible to camera) and blocking the direct light allowing just secondary bounces at the bottom of the building like in a real world.
Looking good. There is one thing that grabs my attention though. On the shot with the entire building (second last image you posted) the building seems to taper out as it gets higher. Is this how the building is designed?
that’s an illusion from using two-point perspective. the verticals do not diverge as your brain would be expecting them to.
really nice work paraganek. the night scene is great.
