Hold Character Animation to Frame
is there a way to make a character’s animation not start until a specific frame number? ie frame 25
thanks
Hello jedchambers,
Not directly, but you can use different approaches to achieve the same result. For example, with the 4D models you can use the “phase” parameter to offset their animation so it starts the cycle whenever you need.
Also, it is possible to apply an offset to the whole simulation of any scene by using the “playback offset” parameter in the plugins (3dsMax and Cinema4D). This parameter can even be animated in 3dsMax to achieve very interesting results:
