HOLICK
Hello!
I have some problem with sharp window corners/curve as you see in renders. How can I fix that?
Did you turn off image sampling completely? Everything so aliased.
I left the standart case options PT+HD.
And you didn’t use any sharpening filter in post production?
either render to higher res and downscale jpeg/png in photoshop, or set internal res multiplier in VFB settings to 2 and increase highlight compression in color mapping
Is there ever any real reason / gain in using a higher Internal value than 2 ? like 4 or 6?
Cheers
