Hologram Shader Material Car Paint
I’m new to CORONA, does anyone knows if this effect (material) is possible to be made in Corona? I guess something with Hologram Shader?
See GIF (applied on car): https://gfycat.com/InfantileDigitalEyas
See GIF (applied on small object): https://gfycat.com/QuarterlyEducatedCommongonolek
It’s not a hologram. This effect is called iridescence. This can be easily done in 3ds Max - here is a guide: Iridescent shader - Corona 1.5.2 - Corona for 3ds Max :: User Contributions - Chaos Forum
Thank you!
Do you also know if this type of shader can be reproduced in corona?
https://gfycat.com/SelfassuredRightCaribou
I’m not sure how the rainbow looking sparkle would be made.
Here is a very quick attempt that probably needs refining. The most accurate way would be adding a normal map representing the flakes, as in the carpaint tutorial here:
rainbow-flakes-2014.max (1 MB)
Hey. I did a “sort” of hologram shader in Corona some time ago…
 You can see the results here : https://vimeo.com/111268491
  Basically i´t s ramp map based on light or camera angly with some gradients of colors on it, and it´s piped to the reflection color masked by a fresnel (if i am not wrong...)
