Hopefully useful tip to avoid end task on GPU failure
So my gpu often works ‘fine’ and then suddenly glitches with a purple warning making everything unresponsive - can’t shut or stop the vfb etc. Presumably when it’s just had enough of me wanting to work :stuck_out_tongue:
Normally I have to end task, which is incredibly annoying.
I found out accidentally today that simply changing to cpu will ‘reset’ things and I can then switch back to gpu to continue the torture without the need for a restart. Hopefully this’ll help others.
Feel free to move this post to another place if it doesn’t fit here :slight_smile:
EDIT: Sorry, this actually does not work and requires a restart even though it resets the vfb. Nice dream.
Please delete therefor :frowning:
