This is something I wish for so long! As I just started to use vantage right now (which is amazing) and found out about the horizontal shift option here I more then ever wish to have a corresponding option in my vray production settings. It is just a small tab and it would help so much! Please add it to the camera.
And talking about the camera: it would be so helpful to have some more advanced safe frame options for composition pruposes like a grid, centre lines, etc…
Please, please, please! I know there are workarounds but they don’t really flow. Archviz within Rhino requires those tools!
Any response from the devs is highly appreciated. Thanks!
The addition of Horizontal lens shift control was indeed not selected for the initial V-Ray 6 release. We are still debating whether to implement it in the main UI or keep it as a semi-hidden option. @toniboni , can you please advise how often do you use it in your projects (via script or in Chaos Vantage) and what shots you mostly use it for?
Thanks for getting back on this. Not using it very often to be honest, but when I need it it would save a lot of time and workaround hustle because I don’t have to render the full stretch and then crop it manually in the end. This also would help to avoid any workflow flaws. I use it only for architectural visualizations, but here I think it would really help to simulate large format cameras and work more professionally. Obviously the by far preferred solution would be the direct control in the rhino viewport but I guess this is beyond your influence.
Thanks for considering!
We would also really like to see vertical and horizontal lens shift options. We use it for architectural visualisations, and this is key for getting the correct render area whilst
maintaining orthogonal view,
You can use the script below to control the Horizontal lens shift. You can do this by running the EditPythonScript command, then copy and paste the script in the Rhino Python Editor and click on the green “Start Debugging” button:
import rhVRay as vray
with vray.Scene.Transaction():
camera = vray.Scene.Plugin("/CameraPhysical")
camera.horizontal_shift = 0.1
You can play with the camera.horizontal_shift value and run the script multiple times until you get a satisfying result. Please let me know if you have any questions.
Hello @studio_plusthree , Vertical shift is exposed in the V-Ray Asset Editor under the Camera settings > Effects > Vertical Lens Tilt (example). Please check this option and let us know if this is what you were looking for.
Hi - thanks for the reply, but we are looking for Shift rather than Tilt.
We are looking to maintain the camera position and orientation (eg to achieve orthogonal projection), but render an area outside of the viewport (for architectural renders)
Tilt obviously changes (tilts) the camera orientation up or down.
it would be great if Horizontal and Vertical Shift was incorporated into the Asset Editor - we used this all the time with Maxwell Render for Rhino.
I understand you can modify the python script in rhino for CameraPhysical, but it would be much easier if there was a setting within Asset Editor. (feature request)
@studio_plusthree thank you for additional information, we have added a comment to the internal case number WEBUI-6387 regarding Vertical shift as well. If there are any updates on this matter we will let you know here on forum.
@natalia.gruzdova@konstantin_chaos The new beta is available and this little basic feature is still missing. Please add it now, I suppose it will be only a few lines of code.
